Transparently this is a major issue that I keep reading in all threads 6100, 8100, 6500ub, 7500ub, 8500ub, 9500ub, and im sure the newer ones 8350, and 8700ub will be affected as well.
I just wanted to help sort things out to see if we can actually see a trend, or a possible way to fix the issue our selves. I'm going to buy the 8700ub or 8500ub soon and I want to take extra pro-cations not to have a premature bulb failure.
Please vote in the poll about bulb life. Just click the nearest one that you would round to. To if you have 150hours just put 200hours. If you have 149 hours you can pick 100hours. Just round like you would in math class.
ONLY VOTE IF YOUR BULB HAS POPPED. DON'T VOTE IF ITS STILL WORKS, INSTEAD ANSWER THE QUESTIONS BELOW.
1) What is the temperature of the room on average? How often do you clean your filter?
2) what size room do you have, is the room big or small, is it near a window or AC unit?
3) Did you make custom fans to point at the projector to help flow?
4) Do you use high alt mode?
5) what settings do you use? like pre-made modes, or your own custom calibrations?
I figured this could help us determine if the bulb design is bad, or the projectors just don't like certain conditions. Or maybe is possible the projector just cant remove the heat fast enough.
If anyone can think of anything else to add feel free to post. Thanks for taking your time to read this and helping the rest of the AV community address this issue.
