Originally Posted by eiger
Epson 7500 owner here -
Can someone tell me how many hours I should expect out of my unit?
2 days ago, I noticed my image start to get significantly dimmer.
I've clocked 2200 hours on it over the last year+. Is this likely a lamp issue? Should I look at installing my spare at this point?
What are other people getting on their 7500s etc. I thought they were rated for 4000. Thx.
It is almost certainly a failing lamp. If you have clocked that many hours than it should not be a surprise. Epson's 4000 hour claim is possible but unlikely. 2000 is standard for competitive brands. If you have not changed any settings or altered any input sources than it is a pretty sure possibility that you need a new lamp. If your projector is still under warranty there is a good chance Epson will replace your bulb for free if you talk the right talk to tech support. Otherwise it is about 300 bucks. If you do elect to purchase a new bulb I would suggest trying to purchase it from Epson if possible. Even if you do get a bad bulb they will replace it without question. Good Luck!
