I switched internet to HughesNet and in the process had to renumber my network (because the HughesNet modem's LAN address is unchangeable).
My 5504 took the change in stride. However, my 5040 is VERY unhappy now and I hope someone has some ideas to try.
I have these fun issues:
1. If I boot the unit up with the network cable plugged in, as long as I have a DHCP server enabled on my network, the unit continually reboots. It gets to the last splash screen before it would actually go live before rebooting. If I disable DHCP or unplug the network cable, it boots.
2. Once booted, I can plug in the network cable. If I initiate a net connect, it goes through the process as usual. It gets to a message like 'getting new phone numbers' and sits there a LONG time... then reboots.
3. I am using a manually configured address (the 5504 uses dhcp, and I am pretty sure the 5040 did too, before). When I set the address, when it checked for the network connection, the countdown timer would hang for a while and eventually the system would reboot. I was able to work around this by unplugging the network cable momentarily at the time of the hang. Voila, the process would complete.
I don't seem to be able to switch to dhcp at all. The countdown similarly hangs, and if I remove the cable momentarily it continues, but eventually fails completely and wants to retry - then again hangs during the countdown and reboots.
I have cleared the guide data (twice in a row) to no avail.
My suspicion is that this has to do with dhcp. My HughesNet modem gives out addresses but they would be on the wrong network because it's on the other side of my wireless router. It seems to me that it shouldn't even be receiving dhcp requests (because it's on the wan side of the router) but as a precaution I tried to block port 68 coming back from the wan side, to stop any DHCP responses. Unfortunately I can't just turn off dhcp on this thing! So while I can turn off DHCP and disconnect the internet to boot it up, I obviously can't net connect without the internet.
