Originally Posted by Franin
No difference at all. Its mainly for stability carrying the signal and avoiding the blu screen due to handshake issues. I remember used to think it was the duo or the pre amp(before I had the duo) and all along it was my bloody cables. I even got rid of my sony bdp 350 because at times it didn't handshake properly.
I noted the more expensive silver-coated cables have a greater percentage of silver coating. The Pangeas have 4%; I saw another (Audioquest I think) at 10%. I do experience audio dropouts and such with my cable TV sometimes, but that could be the source, not necessarily the cables. Then, the recent problem with video from my 09FD turned out to be an HDMI gone bad.
For the cable box, I might go to component for a while and see what happens.
, but it should be cheaper, yes. Then the only problem would be leveling, as the floor here is uneven. Furniture casters, perhaps similar to what I have propping up the front legs of my Hooker cabinet, may work.
