Zuluwalker 11.2 Theater - Page 5
post #121 of 235
Looking good, can't wait for pictures of the frames & fabric.
post #122 of 235
outstanding job!
post #123 of 235
i wish i was at the same stage as you, just fine tuning your theatre. As my mother once told me, all good things take time! Keep up the good work
post #124 of 235
If your going to be in Edmonton sometime, let me know. It would be a pleasure to show the room to you.
post #125 of 235
After weighing the costs of bulb replacement vs. a UPS, an easy decision was arrived at. And I got this baby for a steal
CyberPower CP-1350-AVR-LCD Intelligent UPS
Equipment:
Epson 8100
Elunevision Elara II Silver Pre-lux, 106" fixed frame
Pioneer Elite VSX 21-txh
Pioneer PD-F507 (25 Disc)
Sony PS3 (80GB)
Motorola DCX3400 (HD Cable tuner/PVR)
Polkaudio RTi-A7 (Towers)
Polkaudio CSi-A6(Center)
Polkaudio FXi-A6 (Surrounds, Dipole/Bipole)
Polkaudio FXi-A4 (Rear Surrounds, Dipole/Bipole)
Romanca 12" sub
David Box 12" sub
2 Virtual Dynamics "Testament" Power Cables
1 Monster 300 HDMI 1.3
1 Monster 450SW 25ft (Sub cable)
1 Energy Extreme (Sub cable)
5 Phoenix Gold VRX.600 RCA
Belkin PureAV Isolator (10 outlets, 4720 joules)
post #126 of 235
Great thread....I need to get some bass traps in as well......and get on with finishing!!
Great Work.
post #127 of 235
Have you made the frames yet? What kind of fabric do you use to cover the frames? I am interested in learning how to work with fabric for my theatre (screen wall, walls, bass traps, acoustic treatments, etc), it is not an area I have any experience in.
post #128 of 235
I am done one of the Bass Traps, and already to go on the next. They take a day each, because I wait for the glue to dry.
I will post some photos tonight if possible, otherwise tomorrow. I bought a nice fabric that is sheer enough, without being too thin. I think it all worked out. If you want to see them when they are done, and look at my other photos of them, it would be cool with me if you wanted to come over and see for yourself.
post #129 of 235
post #130 of 235
post #131 of 235
post #132 of 235
I tried out a few pieces of 90 degree corner edging, and I liked the results. I will again stain them to match the columns and other accent wood in the room.
To remove the wrinkles in the fabric, I will place it in the dryer for a quick steam, so the wrinkles lift out and it is flat when I stretch it.
post #133 of 235
Looking good.
I would definately like to visit your theatre, it is about the same dimensions as I have to work with, I'll PM you.
post #134 of 235
Panels for front side walls
Bracket reinforces the screw, and 2" nails, with glue.
post #135 of 235
2 x 51" by 33 3/4"
Sprayed black so they don't show through the fabric.
post #136 of 235
What size(s) of wood are you using for the outside frame, and the internal supports?
How big are the pannels?
post #137 of 235
51" by 33 3/4"
I used 1x4, and the supports were made from some scrap wood that was already ripped, on a table saw,to a unspecified size (basically left overs from another project).
post #138 of 235
Some more accoustic treatments...
These panels need material stretched over them, I plan to do it this weekend!
post #139 of 235
post #140 of 235
This frame covers a window, which I built shutters, to block light from entering. There is an exact mirror copy on the opposite wall, to create symmetry. The panels were not specifically created to address any accoustic issues, as much as it was designed to block the shutters on the window.
post #141 of 235
I'd be flattered to have any of my ideas in here!!!! Good looking theater!
post #142 of 235
With the panels, corner traps, and new pads in the room, things are sounding better than ever. Although I have noted that volume can go louder than before and still sound great. I am so thirsty for more power. Under strong consideration now is the 8 channel, Marantz mm8003.
post #143 of 235
post #144 of 235
One panel left to build for the front of the room, behind the Center channel. It will be approx 8ft long and 2ft in height by 3 1/2inches thick.
I will then cover it in the same fabric as the front top panels, and I will complete the rear corner Bass traps with that material as well.
post #145 of 235
post #146 of 235
post #147 of 235
Finally finished and covered the rear bass traps in the corner. They look really good in person!
post #148 of 235
post #149 of 235
It is really odd to feel like my long list of jobs, and additions is near the very end. And for any sad feelings I may have about being "done", I will just have to remind myself ... that it is prudent to upgrade equipment every five years!!!
post #150 of 235
I have just learned not all measuring tapes are the same! I mean I knew this of course, but I have just been burned by a bad measurement... and frankly I am amazed!!?!!
- Either I was crack when I built my room,
or
- I did a crappy job of measuring the first time and never checked again (I doubt this one),
or
- My orignial measuring tape sucked and was off by two inches!!!?!!!
or
- My room is magic and it's growing?
Final length of the room...18 feet 5 inches!!!?!!! WHAT THE HELL??? Aren't measuring tapes checked against some sort of standard!!!
