Zuluwalker Theater Build - Page 5
post #121 of 212
Bass traps
Roxul, Safe n' Sound - 3" thickness
I had a movie playing while I was installing these and a TV show (at different times during the day), and I was startled to quickly and easily hear the difference the traps were making in the sound of the room. When I was done for the night, I sat back and listened carefully, a noticeable shift in clarity was now present that I had not heard before.
post #122 of 212
Now I need to build frames, then stretch a fabric over the traps for the rear corners. The front are covered by the curtains.
post #123 of 212
Before the bass traps
After adding bass traps
Center channel with no calibration and no bass traps
Center channel with calibration only
Center channel, re-calibrated with Bass Traps
Front speakers, calibrated with Bass Traps in the room
post #124 of 212
Looking good, can't wait for pictures of the frames & fabric.
post #125 of 212
outstanding job!
post #126 of 212
i wish i was at the same stage as you, just fine tuning your theatre. As my mother once told me, all good things take time! Keep up the good work
post #127 of 212
If your going to be in Edmonton sometime, let me know. It would be a pleasure to show the room to you.
post #128 of 212
After weighing the costs of bulb replacement vs. a UPS, an easy decision was arrived at. And I got this baby for a steal
CyberPower CP-1350-AVR-LCD Intelligent UPS
Equipment:
Epson 8100
Elunevision Elara II Silver Pre-lux, 106" fixed frame
Pioneer Elite VSX 21-txh
Pioneer PD-F507 (25 Disc)
Sony PS3 (80GB)
Motorola DCX3400 (HD Cable tuner/PVR)
Polkaudio RTi-A7 (Towers)
Polkaudio CSi-A6(Center)
Polkaudio FXi-A6 (Surrounds, Dipole/Bipole)
Polkaudio FXi-A4 (Rear Surrounds, Dipole/Bipole)
Romanca 12" sub
David Box 12" sub
2 Virtual Dynamics "Testament" Power Cables
1 Monster 300 HDMI 1.3
1 Monster 450SW 25ft (Sub cable)
1 Energy Extreme (Sub cable)
5 Phoenix Gold VRX.600 RCA
Belkin PureAV Isolator (10 outlets, 4720 joules)
post #129 of 212
Great thread....I need to get some bass traps in as well......and get on with finishing!!
Great Work.
post #130 of 212
Have you made the frames yet? What kind of fabric do you use to cover the frames? I am interested in learning how to work with fabric for my theatre (screen wall, walls, bass traps, acoustic treatments, etc), it is not an area I have any experience in.
post #131 of 212
I am done one of the Bass Traps, and already to go on the next. They take a day each, because I wait for the glue to dry.
I will post some photos tonight if possible, otherwise tomorrow. I bought a nice fabric that is sheer enough, without being too thin. I think it all worked out. If you want to see them when they are done, and look at my other photos of them, it would be cool with me if you wanted to come over and see for yourself.
post #132 of 212
post #133 of 212
post #134 of 212
post #135 of 212
I tried out a few pieces of 90 degree corner edging, and I liked the results. I will again stain them to match the columns and other accent wood in the room.
To remove the wrinkles in the fabric, I will place it in the dryer for a quick steam, so the wrinkles lift out and it is flat when I stretch it.
post #136 of 212
Looking good.
I would definately like to visit your theatre, it is about the same dimensions as I have to work with, I'll PM you.
post #137 of 212
Panels for front side walls
Bracket reinforces the screw, and 2" nails, with glue.
post #138 of 212
2 x 51" by 33 3/4"
Sprayed black so they don't show through the fabric.
post #139 of 212
What size(s) of wood are you using for the outside frame, and the internal supports?
How big are the pannels?
post #140 of 212
51" by 33 3/4"
I used 1x4, and the supports were made from some scrap wood that was already ripped, on a table saw,to a unspecified size (basically left overs from another project).
post #141 of 212
Some more accoustic treatments...
These panels need material stretched over them, I plan to do it this weekend!
post #142 of 212
post #143 of 212
This frame covers a window, which I built shutters, to block light from entering. There is an exact mirror copy on the opposite wall, to create symmetry. The panels were not specifically created to address any accoustic issues, as much as it was designed to block the shutters on the window.
post #144 of 212
I'd be flattered to have any of my ideas in here!!!! Good looking theater!
post #145 of 212
With the panels, corner traps, and new pads in the room, things are sounding better than ever. Although I have noted that volume can go louder than before and still sound great. I am so thirsty for more power. Under strong consideration now is the 8 channel, Marantz mm8003.
post #146 of 212
post #147 of 212
One panel left to build for the front of the room, behind the Center channel. It will be approx 8ft long and 2ft in height by 3 1/2inches thick.
I will then cover it in the same fabric as the front top panels, and I will complete the rear corner Bass traps with that material as well.
post #148 of 212
post #149 of 212
post #150 of 212
Finally finished and covered the rear bass traps in the corner. They look really good in person!
