A little history lesson,
This bad boy was responsible for a lot of trouble. The drain was directly below the wall that separated the old guest room, from the old family room. Once a leak was detected, I was forced to pull up the carpet on both sides of the wall, and then subsequently tear down the wall and hire a plumber. It was necessary for the plumber to jack hammer the concrete to access the drain pipe. He then did a better than necessary job, and charged me a bazillion dollars for four hours work. Afterwards, it was completely necessary to not rebuild the wall, or the old guest room; it was crucial we instead build a Theatre Room...
1 Leaking Drain Pipe
2 Soiled carpets
1 Demolished Wall
1 Expensive Plumber
= 1 Awesome Theatre Room...Priceless$$$
I also deny all alligations as non-sense, that I caused the leak, pure hear-say! How many shoes and purses does it take to clear a guilty conscience? I'm guessing it will never be enough...
2 Soiled carpets
1 Demolished Wall
1 Expensive Plumber
Thanks for your interest!
