AVS › AVS Forum › Other Areas of Interest › CE Pro & Electronic House Articles › Trump Tower Condo Uses Shades as 110" Screen
post #1 of 5
By Lisa Montgomery
No room for a big screen? Think again. Here's a viable alternative.
Think you have no room for a big screen in your bedroom? Think again.
The renter of this one-bedroom condo in the Trump Tower in Chicago uses the shades that cover an expanse of floor-to-ceiling windows as a display. It's less than a perfect setup, admits Brian Miller of Connecteriors, the firm that played a role in designing the clever application. A window shade is never going to give you the color imagery or the black levels of a specialty theater screen, he says, but in this particular room, it was the best option.
Most of the wall space was consumed by windows, which limited the mounting options for a flat-panel TV. An entertainment cabinet or shelving system was out too, as the room simply wasn't large enough to accommodate another piece of furniture. Installing a retractable screen was considered, but the renter didn't feel comfortable pursuing a complicated construction project.
The idea to use the window shades as a screen started when the interior designer, Briana Steele of Chicago-based theorie, randomly mentioned it, says Miller. But after thinking about it, and looking at shading fabrics [from Lutron], we thought it just might work. The renter knew it wasn't going to be ideal, performance wise, but he was willing to take the risk.
Connecteriors tested several fabrics at their shop, and ultimately chose a white blackout material from Lutron Electronics. It was the most characteristic of a projection screen, says Miller. Two panels of the blackout shades, in addition to a two panels of transparent window sheers, would be attached to a motorized assembly mounted at the top of the window. All four panels can be operated via a handheld universal remote or a wall-mounted keypad at the entrance to the room.
Click here for photos.
Click here to continue.
post #2 of 5
Don't like this at all...look at all the light coming in during the day. I'm sure it's better at night but definitely not optimal for home theater viewing...and there is no masking at all...bleh...might as well put up a white sheet and call it a day.
post #3 of 5
Put up a white sheet where? That's the point of the article. There was no room for a white sheet.
post #4 of 5
On the window, duh! why spend thousands for that set up when you can be more economical...please don't defend this waste of money.
post #5 of 5
You aren't serious are you? A white sheet wouldn't work nearly as well as the blackout clothe curtains used here since the sunlight would go right through it. Wouldn't look very elegant either.
And, as already mentioned, it will look way better at night, and that is probably when the owner mostly uses it. Even so, it probably works better during the day than the picture implies. The camera is likely exposing to make the white curtains bright, so in person the projected picture probably wouldn't be so washed out.
