Originally Posted by sean_w_smith
Not exactly, Those features all existed in XBMC before boxee or plex even existed (about 8 years now). A mac mini running XBMC will do this nicely. If you like boxee and your goal is local playback you will like XBMC more. Boxee's strength is in some social and WAN features.
most of us all control our HTPC's using IR and our universal remotes like every other AV component. I only dust off the keyboard if I want to run firefox, etc... There is extensive IR software for windows and mac if your app doesn't play nicely like XBMC.
I would recommend playing with your HTPC some more. There is a untapped potential it sounds like
Thanks, I have started to figure out that nearly all of the features I liked in Boxee are in XBMC. I just happened to install Boxee a year ago, and liked the features, so I never explored other options. Now that Boxee is nolonger being developed for the Mac (or any other OS other than Boxee hardware), I started to investigate other HTPC options. Now, I like XBMC-Eden more than I ever liked Boxee.
Still need to resolve the remote issue. I had been using the Apple remote with Boxee, and it worked well, but the Apple remote barely works with XBMC. I can access the main functions, but there are many functions I am forced to use the mouse\\keyboard.
I also would like to know how others control iTunes from within XBMC using their remote. At the moment I have to use the keyboard to switch iTunes, and then use the keyboard\\mouse with iTunes (no remote). This really does not work as a HTPC solution, so I need to figure out a way too access iTunes content through XBMC, using a remote.
