Originally Posted by charlyz
Hello, I'm not sure if this is the correct forum for my question. But I'll try
I have an ATV and spend many time streaming through AirPlay in my main zone. In another room I have two pretty speakers connected to an ext amp, but not wired to my main receiver. So I'm wondering how can I do to use them with AirPlay. What I want to do is streaming from my idevices via AirPlay and listen in those speakers. In one word: convert my standard speakers in AirPlay speakers. I saw the airport express comes with audio output but I don't sure if that is what I need.
Any ideas?
Any ideas?
Airport Express should do exactly what you need. AppleTV would also work but you really need a TV connected to see the interface, while AEX has no interface so no problem there. You could run another ATV (once set up on a TV to connect it) "headless" with no interface, if you prefer, since AirPlay "pushes" to the ATV so not 100% essential to work with the interface, especially if you might add a display there in the future, but that's your call.
