Originally Posted by lovswr
Sorry that is what I meant. Wired GigabitEthernet.
The 8 port switch is by D-link. The Netgear router & the switch are both less than 6 months old (at least I bought them in the last 6 months). The cable is Cat-6.
I really just wanted to know if there was anything specifically to the second generation AppletV that I should look out for.
Is the router wireless? Set the atv to dhcp (probably already there) and unplug the Ethernet cable. It should then just work. If the router is wireless N then there shouldn't be a big advantage using wired 100mbs ( the ATV Ethernet is not gigabit so you won't be able to get the gigabit advantage- true for almost every media player). If you can use the 5Ghz band, if available. The reason for trying wireless first is that you can rule out problems with the network topology, since you have a switch and a router.
It's probably a firewall thing. I have several switches and a couple of wireless access points. The ATV just worked.
Philip
Two Saturdays ago they had a dozen or so and sold out the same day. Last Friday they had roughly the same amount and again sold out the same day.
