Apple TV owners' thread. - Page 73
post #2161 of 3001
The bigger your display the better is Blu-ray by comparison.
post #2162 of 3001
Just got Apple Tv 3 yesterday connected it to ethernet (modem is by TV setup). I am able to stream from 2 laptops and stream and mirror from Ipad 3 but photos have large black bars on sides and HBOGo has smaller black bars.Connected Apple tv to video (input 4 on receiver thru ARC) on Sony STr 520 receiver with 60" Sharp lc60LE640u TV. What program should I choose to steam? Set Apple Tv to 1080p as my tv supports that format.
post #2163 of 3001
iPhone/iPad photos are 4:3 aspect ratio - so yes you will get bars with photos.
I use the native HBOGO app on the ATV - no black bars here. Have you tried that.
I haven't tried mirroring the HBOGO app from my iPad - but I suspect you may be seeing issues related to the fact the iPad screen ratio is also 4:3 not 16:9 like your TV.
post #2164 of 3001
Ok. So I would turn off mirroring and just stream? What do you mean by native on HBOGO? Is that in settings? did't see it.Sorry for my ignorance on this.
post #2165 of 3001
HBO GO was added in a recent software update. Check to see if you have ver 5.3 (6106). If not, click Update Software.
post #2166 of 3001
To play HBOGo from your iPad to your Apple TV turn AirPlay on without mirroring. You may have black bars on the top and bottom of the screen depending on the source material. You would only have black bars on the sides if the source is 4:3. The Apple TV also has an HBOGO app, but your cable company has to activate it. Mine currently does not.
post #2167 of 3001
I have Directv which allows me to use. Will turn off mirroring; thought it would be a great feature but not sure where it is very usefull.
post #2168 of 3001
I also use my ATV as well as blurays. Not ready to handover the reins just to digital/streaming. I also like having multiple sources for content.
post #2169 of 3001
With DIRECTV you can use the Apple TV HBOGO app.
post #2170 of 3001
Mine on Ipad says version 2.1.0.926-but don't see how to update. is update thru Ipad or Apple TV?
post #2171 of 3001
Apple Tv
post #2172 of 3001
I'm talking about the applet on the AppleTV.  The iPad is not involved when you use HBO GO directly on the ATV.
post #2173 of 3001
So it is better to use Apple tv HBOGO than the IPAD app?
post #2174 of 3001
I wish apple would put safari on Apple TV
post #2175 of 3001
Yes, but try it and come to your own conclusion.
post #2176 of 3001
Seriously? Of course!
post #2177 of 3001
Yes, the HBO GO app on the ATV is a better option....no buffering or 4:3, just excellent quality streams.
post #2178 of 3001
I think it's the same, quality-wise, but more convenient on the ATV. The iPad app gives HD and 5.1 surround sound, as long as you use airplay from the HBOGo app and don't use mirroring.
post #2179 of 3001
I really wonder if that would be a good idea. You can always use your iPhone and project the browser onto a screen. I don't think a browser and TV mix well. In the past people wanted access to flash sites on a TV and so they wanted a browser.
In any case this really is a tricky area. Having a browser on Google TV has done little for that platform. The whole app thing on a media player is a bit strange to me. Most of the apps for Google TV, smart TV'S and so on are junk. Kind of like cable with its 95% junky channels.
Philip
Sent from my GT-N5110 using Tapatalk 4
post #2180 of 3001
Based on my PS3 experience it's a terrible idea.
post #2181 of 3001
No. Use a computer if you want surf the web.
post #2182 of 3001
Originally Posted by tre74 View Post
HDMI-CEC would be a nice addition to the next gen box.
That's probably my biggest complaint about the AppleTV, Airplaying would be a lot nicer if it would automatically turn the ATV on and switch to the correct input.
HDMI-CEC is kinda goofy anyway, my Denon always turns on & is like "hey the TV's on so I need to switch to that input!" even when the cable box is on.
Then again I hardly ever use the apps on my Samsung or play Blu-Rays anymore so I guess I could just turn it off & then it wouldn't switch like that.
post #2183 of 3001
Apple is not going to pay the hdmi cec license for each box. It would be nice, but I don't see that happening. Same reason they don't pay for hdmi in their laptops or desktops (except the mini) or why there is no bluray. They push their own agenda/technologies.
post #2184 of 3001
Generally I keep CEC turned off if possible.
I use a Harmony remote to switch 'activities' and CEC has a tendency to mess with this.
That said I had to enable CEC on my AVR when I started to use ARC recently.......
post #2185 of 3001
I'm clueless! have my Apple Tv 3 hooked up to Sony Str 520 reciever thru ARC (hDMI). Just got it a few days ago but seems to work fine. What the heck is CEC?
post #2186 of 3001
Internet search is a handy tool:
http://en.wikipedia.org/wiki/HDMI
post #2187 of 3001
ARC is used to send sound from a TV to an AVR without a separate optical connection and, as such, has nothing to do with an ATV.
Edited by BIslander - 8/7/13 at 8:42pm
post #2188 of 3001
I noticed it said LCPM on recever. Would optical get me DD sound?
post #2189 of 3001
ARC is an audio path FROM your television's audio decoder TO another device. Commonly an audio amplifier. The type of cable or signal being replaced isn't really relevant. So it could be optical, coax or analog. LPCM typically means the signal is being decoded (from say DD to six discete uncompressed channels) in the televison rather than your AVR and isn't related to the number of channels being presented.
post #2190 of 3001
HDMI will get you DD as will optical or coax. If you are only getting PCM, that's a problem with the setup of your ATV. You need to set the output to Dolby and select programs with DD 5.1 soundtracks.
