Originally Posted by losmi8
also...i can only mount the project straight back from where the picture is going to be, correct? i cant project a picture from the side?
yes it basically has to be straight back otherwise the picutre is distorted (think like how your shadow distorts as the sun moves across the sky)
keep in mind that diff pjs have diff mounting height location ranges
some can be mounted at the same level as the screen, others like this one are quite a bit above or below the screen, so you'll need the room
check the manual online or projector reviews calculator
screens are a whole nother subject; you can spend as much as the pj on one. nobody can tell what the "best' screen is, except maybe telling you about one of the higher end well renowned models that cost as much as this PJ. spend time in those screen forums for ideas.
and yes, generally the price always drops, hard to tell where when and so forth
