AVS › AVS Forum › 3D Central › 3D Source Components › no 3d on my hdtv
no 3d on my hdtv
post #1 of 3
I have samsung dlp 3d ready hdtv hl72a650 and the mitsubushi 3da1 adapter and the hdmi detective plus with my ps3.my 3d mode is not working on the adapter.i used the tru3d directions and still no luck.can someone help me out.
post #2 of 3
Did you rescan your video settings on the PS3 when hooked up to the adapter? If not, you won't get 3d from the PS3.
The PlayStation®3 system software version 3.50 update includes the following:
Blu-ray 3D disc playback
The PS3 system can now play 3D content on Blu-ray 3D discs.
An HD 3D display, active 3D glasses, and a high-speed HDMI cable (each sold separately) are required for 3D features. Visit www.us.playstation.com/support/3D for details.
Limitations on Blu-ray 3D disc playback
The 3D display of some elements such as menus and subtitles may be different on the PS3 system than on other 3D playback devices.
Depending on the content, some BD-J (Blu-ray Disc Java*) features such as BONUSVIEW and BD-Live may not play in 3D or may not function properly on the PS3 system.
When Dolby TrueHD is selected as the audio format, audio will be output in Dolby Digital during playback of Blu-ray 3D content.
When DTS-HD is selected as the audio format, audio will be output in DTS during playback of Blu-ray 3D content.
*Blu-ray Disc Java provides enhanced bonus content, including network access, picture-in-picture (PIP) functionality and expanded local storage
Technical Requirements:
PS3 firmware v3.30 or higher
Full HD 3D television with compatible 3D active glasses
Highspeed HDMI cable
Make sure PS3 display settings are set to "automatic". On the XMB go to, (Settings) > (Display Settings) > [Video Output Settings] > HDMI > AUTOMATIC.
From the PS3 FAQ thread: http://www.avsforum.com/avs-vb/showthread.php?t=931796
PS3 Support for 3D Games and Blu-ray 3D
The 3D features of the PS3 can only be enabled once the PS3 is connected to a compatible 3DTV that supports the Frame Packing 3D signal format as defined in the HDMI version 1.4a specification. 3D support is only available via the PS3's HDMI output. Although the PS3's internal HDMI hardware is based on the HDMI version 1.3 specification, firmware updates are able to add software to provide emulation of the essential 3D features as required by the HDMI version 1.4a specification. Any device, such as an Audio/Video Receiver or an HDMI switch, that is used between the PS3 and the 3DTV must be able to support HDMI 1.4 in order for the 3D capabilities to be available. You do not necessarily need to replace your existing HDMI cables as most HDMI cables that are certified as HDMI 1.3a (or 1.3b) Category 2 should work. If buying new cables look for ones labeled as HDMI High Speed - they are now available from such sources as monoprice.com.
Blu-ray 3D Support: The tentative release date is September 21, 2010 for the PS3 firmware update from Sony that will enable Blu-ray 3D playback capability. The PS3 will use the HDMI Frame Packing 1080p/24 format for the output of movies from Blu-ray 3D discs.
Games: The PS3 can now be set to output the 3D in a format that works with the new 3DTVs (i.e., Frame Packed 720p/60 3D format as defined by the HDMI 1.4a specification for games). Below are the steps for the PS3 setup.
* Connect the PS3 via HDMI to a 3D capable TV (i.e., one listed as 3D capable and with an HDMI version 1.4 input, or at least the HDMI 1.4 feature subset required for 3D support)
* Use the TV's menus to enable the 3D function (not just 2D-to-3D conversion)
* On the PS3 go to "Settings" then scroll to "Display Settings"
* Select "Video Output Settings"
* Highlight "HDMI" scroll right
* Select "Automatic" scroll right
* Screen will turn black then come back on
* Highlight "YES" (Make sure you highlighted "YES") and Select it
* A dialog comes up stating your TV supports 3D enter your screen size here then scroll right
* You have completed enabling 3D on the PS3
post #3 of 3
Use existing topic at top of forum.
  Back to Forum: 3D Source Components
This thread is locked
