Originally Posted by bhazard
That's simply not true either unless you are talking about the lower end models. I measured my Onkyo 608 and it put out around 30-35w x7, while my 1121k easily pulls around 65w x7 rms. The 709 and 1121k have the same power spec and put out the same amount of power.. with the 1121k being ~$100 or $200 cheaper if bought on Black Friday.
The 1019 was rated at well under 40 watts when tested. The newer 1021 isn't much better.
I have the 919 and it barely drives my 98db speakers at decent levels. The pioneer speakers are decent speakers, and great speakers at their price point. The pioneer amps are feature loaded but are weak on the amps except for the thx rated elite amps, which aren't all that stout either.
The low-mid range onkyo has a much better amp, if it doesn't burn your house down.
I stumbled upon my answer in a pair of JBL Studio 180's - so surprised they are voiced very very similar to the BS-41's. I A/B them back and forth and their mid range are largely the same to my ears. Two areas where the 180's claim clear victory: high end and imaging. 180's tweeter is fantastic, crystal clear without a slightest hint of harshness. And 180's imaging is just crazy good. They have the same expansive sound stage as BS-41's, but much clearer sense of location.
