Originally Posted by AJCxZ0
Model? I love my Viera TC-P50G25.
No-one deserves to have to listen to sound from a TV any more than they should watch a picture on a speaker. Glad to hear you didn't waste money on the unacceptable compromise - the sound bar.
This may be tough, since this current range of speakers is going out of production. That's why we keep seeing these clearance deals. One the vendors are sold out, you may have trouble finding them used.
For $20 less than a new Pioneer sub, this may not be such a good deal, but if you ask little of it, then I'm sure it will perform adequately in your space.
On your budget you should definitely buy a used 5.1 receiver from Craigslist or the equivalent. You don't mention what your sources are, but unless you need HDMI switching, you can get a receiver which gives you great sound via digital audio connections - optical and/or co-axial - for a fraction of the cost. The savings are far better spent elsewhere, such as $129 for the SP-FS51 or $99 for the SP-BS41-LR.
I'd sell you my old but perfectly operational Sony STR-DB840 receiver for $5 if you come and get it.
Don't waste money on fancy wires and cables. Monoprice has excellent products at reasonable prices.
In your position, I'd sell the sub, buy a cheap receiver and get the SP-FS51 and as many SP-BS21-LRs as my budget affords until I can build a 7.1 system, until which time the "spare" SP-BS21-LRs will do duty in other stereo setups (which is exactly what I have done). In your space the floor standing speakers will probably give you more enjoyable bass than bookshelves and a crummy sub. Later, when the budget allows and you have a bigger space, you can get a good sub from one of the reputable direct sale sub makers.
I have 50UT50 great stunning Picture particularly in a dark room.
I now BS21 is quite entry level, but I am starting with them with AVR & Sub and once I'll find a deal on FS51 or some others, I'll use BS21 pair as side/rear.
I am not getting Polk PSW10. GOing to get either of Pioneer SW8 or BIC V80. For AVR, eyeing on craiglist, or will get Denon 1612.
Thank you for your all information...
Also, I haven't SEEN these speakers in a store, so I'm unfamiliar with how big the 41s are. Will they be difficult to wall mount?
