That sounds crazy. My only guess would be something like how noise canceling works.
post #31 of 4205
10/2/10 at 7:27pm
After you remove the 4 screws, you may have to lightly wedge a flathead screwdriver in between the terminal cup and the cabinet until it pops off. Then slowly glide it out of the cabinet. Just make sure you don't pull too hard and rip off a soldered speaker wire connection from the crossover. It looked quite impressive to say the least and looked ten times better than the crossovers inside of the Monitor Audio's that these are replacing.
. I didn't get to listen as long because BB was closing but from what I heard, I don't know how I could justify the price of the Klipsch speakers (compared to the Pioneer towers). I am not going to state that a pair of $200 speakers destroyed the klipsch offering as I only had about 20 minutes with them. I will say though that what I listened to (pioneer wise) is a set of towers that could easily sell for twice their price.
. I am still debating on the tower vs the bookshelf ( which I would have to order from pioneer directly).
