I was just at Best Buy and decided to pick up a pair of the BS21 bookshelves and the C21 center channel just because and for $170 for the set, I could easily find a use for them if I didn't like them.
I havent had time to listen to them yet but the finish and build quality is far better than anything even close to their price. They are also surprisingly heavy given their price. I'll update when I get them setup somewhere.
) to listen to the subwoofer. I will say that it is way underpriced. It holds it's own against my Energy V8 which is also an 8" subwoofer that cost me over double the price compared to the pioneer. It doesn't go as deep as my outlaw sub but then again that is a 10" subwoofer. It's almost like you should ad a minimum of $100-$200 to the price of each speaker in this line to really see the value you are getting compared to higher priced brands.
