AVS › AVS Forum › HDTV › HDTV Technical › Comcast HD vs Uverse HD
post #1 of 4
I couldn't figure where to put this so here it is. I currently have Dish Network and I am considering the switch to either Comcast or Uverse. I was wondering who, in your opinion, has the best HD picture: Dish, Uverse or Comcast?
Thanks for your input,
post #2 of 4
Having had both I'd say they're very close in picture quality.
post #3 of 4
Thanks for that info.
Has anyone ever looked at Dish and are you able to make a comparison? I don't want to ditch Dish and wind up with something inferior.
post #4 of 4
In most all areas, U-verse is considered less in HD image quality than Comcast. Having said that, Comcast can vary from area to area, while U-verse is consistent.
Dish or DirecTV are closely rated, with DirecTV having an edge. Both Dish & DirecTV are usually rated better than U-verse and slightly less than Comcast.
Verizon FiOS is the best but not available in all areas, in particluar where U-verse is available.
I would suggest asking others in your area, in the HDTV Locals Forum: http://www.avsforum.com/avs-vb/showthread.php?t=1269188
  Back to Forum: HDTV Technical
