Originally Posted by
jobu01
From the manual, the 4810 has a table on assigning its amps/speaker terminals, does anyone know which signals can be sent to the 3 assignable amp/speaker terminals on the 4311? The manual for the 4311 doesn't specify. =(
the manual DOES specify, you just may not speak fluent "Denon-ese"
the biggest advantage the 4810 has over the 4311 is the "free assign" mode in which you can assign any of the 9 amps to any channel (including other zones). So you could, for example, run an 11-ch setup with all external amps for the Main Zone, and then use the other 9 amps (internal) to power 9 speakers distributed throughout the house.
the 4311 has a more traditional amp assign scheme, where you are locked into a few pre-determined permutations. The "core" 5.1 channels (L/R/C and SR/SL) are "locked in" to their speakers terminals. The other 4 amps are fully assignable, to your choice of height, wide, surr.back, bi-amp, zone 2, or zone 3, depending on how you configure it. So on the 4311, even if you had 11 external amps for Main Zone, you still could only re-purpose 4 amp channels for other zones.
