AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Software › Cinema Paradiso (1988) Blu-ray and DVD comparison
post #1 of 7
BD from Arrow Films in the UK. The DVD is the swedish release.
The DVD:
Video: MPEG-2, AR 4:3, 25fps, 720x576, PAL
Audio: Italian Dolby Digital 2.0
The Blu-ray:
Disc Title: CINEMA PARADISO
Disc Size: 38*213*514*096 bytes
Protection: AACS
BD-Java: No
Playlist: 00000.MPLS
Length: 2:04:05
Total Bitrate: 33,19 Mbps
Video: MPEG-4 AVC Video / 27999 kbps / 1080p / 23,976 fps / 16:9 / High Profile 4.1
Audio: Italian / DTS-HD Master Audio / 5.1 / 48 kHz / 1829 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 16-bit)
Audio: Italian / LPCM Audio / 2.0 / 48 kHz / 1536 kbps / 16-bit
BD Bitrates:
Code:
        Total   Video
00000.MPLS                                                      AVC     2:04:05 30 892 274 112  38 213 514 096  33,19   28,00   DTS-HD Master 5.1 1829Kbps (48kHz/16-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Size:      38 213 514 096 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:04:05 (h:m:s)
Size:                   30 892 274 112 bytes
VIDEO:
MPEG-4 AVC Video        27999 kbps          1080p / 23,976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             Italian         1829 kbps       5.1 / 48 kHz / 1829 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 16-bit)
LPCM Audio                      Italian         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
FILES:
00000.M2TS      0:00:00.000     2:04:05.855     30 892 274 112  33 191
CHAPTERS:
1               0:00:00.000     0:09:34.282     24 609 kbps     44 549 kbps     00:09:04.585    36 031 kbps     00:09:14.303    33 584 kbps     00:09:10.466    128 293 bytes   425 995 bytes   00:00:05.964
2               0:09:34.282     0:09:13.177     28 218 kbps     44 821 kbps     00:09:37.743    37 822 kbps     00:17:26.420    36 132 kbps     00:17:26.420    147 116 bytes   387 157 bytes   00:17:14.700
3               0:18:47.459     0:07:52.388     28 140 kbps     45 691 kbps     00:22:51.286    38 274 kbps     00:22:03.322    34 985 kbps     00:23:01.797    146 707 bytes   392 251 bytes   00:22:06.867
4               0:26:39.848     0:09:48.337     30 195 kbps     45 201 kbps     00:31:41.524    40 010 kbps     00:36:01.701    37 581 kbps     00:36:01.701    157 423 bytes   396 485 bytes   00:35:40.555
5               0:36:28.185     0:07:50.470     30 447 kbps     46 036 kbps     00:43:11.964    37 990 kbps     00:37:16.442    35 636 kbps     00:42:37.304    158 739 bytes   425 888 bytes   00:36:51.167
6               0:44:18.656     0:07:39.584     28 046 kbps     45 116 kbps     00:50:58.555    40 745 kbps     00:47:36.478    36 198 kbps     00:47:32.516    146 221 bytes   386 878 bytes   00:45:12.835
7               0:51:58.240     0:11:10.419     29 235 kbps     46 355 kbps     00:55:52.015    37 432 kbps     00:55:50.013    35 392 kbps     00:53:28.955    152 416 bytes   385 138 bytes   00:55:45.925
8               1:03:08.659     0:11:21.806     28 287 kbps     45 134 kbps     01:06:13.094    39 471 kbps     01:07:39.597    36 700 kbps     01:07:37.219    147 474 bytes   420 424 bytes   01:06:14.011
9               1:14:30.466     0:13:51.455     27 222 kbps     44 577 kbps     01:24:41.659    38 072 kbps     01:24:41.117    35 248 kbps     01:19:54.539    141 924 bytes   430 637 bytes   01:24:51.252
10              1:28:21.921     0:08:59.247     28 222 kbps     46 583 kbps     01:31:59.472    40 566 kbps     01:31:58.262    36 117 kbps     01:29:24.692    147 139 bytes   440 839 bytes   01:32:16.113
11              1:37:21.168     0:24:16.121     28 053 kbps     45 033 kbps     01:59:40.715    40 968 kbps     01:42:22.135    36 348 kbps     01:42:21.677    146 256 bytes   432 233 bytes   01:38:03.210
12              2:01:37.290     0:02:28.565     19 368 kbps     31 781 kbps     02:01:37.373    24 041 kbps     02:01:37.290    23 233 kbps     02:03:17.014    101 034 bytes   306 093 bytes   02:03:47.211
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     7445,772                28 000                  26 059 863 063  141 735 773
00000.M2TS      4352 (0x1100)   0x80            LPCM            ita (Italian)           7445,772                1 542                   1 435 561 808   8 935 032
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       ita (Italian)           7445,772                1 829                   1 702 699 168   9 977 016
Blu-ray to the left, DVD to the right.
post #2 of 7
theatrical cut :/
post #3 of 7
what about subtitles? forced, burned-in or removable?
post #4 of 7
You forgot to un-squeese the dvd. It is anamorphic, yes?
post #5 of 7
Originally Posted by Thunderbolt8 View Post
theatrical cut :/
The dir. cut do suck. Too long and too uninteresting. Maybe the only dir. cut I don't prefer.
Seems to be forced english. I'll confirm that later.
Yeah, I know. Realised it too late though.
post #6 of 7
Utterly craptacular.
post #7 of 7
no way, with the theatrical you've seen only like half of the movie.
  Back to Forum: Blu-ray Software
