Sorry to hear the news. Mine started last week with one single white dot and now I have 8 with a couple black dots.
Do you have a warranty? If you do, take advantage of it because from what I understand a new light engine, which is what you'll need, is very costly. I would predict them to be between $750 and $1000. I do not know yet, because I am under warranty and the tech. is going to order it. I will probably know within a week or so.
If you do not have a warranty, then you are SOL. You could attempt to fix it. If I were forced to fix mine, I would of course start by trying to find a light engine for cheap. Then its a pretty simple process. From what I understand, the light engine sort of slides out, and the new one slides in. You could attempt to change out the "DMD chip" that Samsung owners have done with their white spots on their DLP sets. That would be more labor intensive although cheaper. I have read that those who changed out "DMD chips" also had picture quality issues.
Anyways, I am sorry about this for you, and Mitsubishi basically SUCKS.
Regarding your silly question: a 73" tv is usually placed against a wall..right? Or is yours sitting in the middle of the room? Call me crazy but I decided to push the limits for waht this TV was designed for and placed my against a wall within a room air conditioned at 78F.Please go away and do not come back
It's been great for over 3 years so I can't complain, but I thought i'd only have to replace the bulb, now its the bulb (at some point) and possible the light engine from what I've read...might as well buy another tv for that kind of money...f'n sux...
