http://www.audioholics.com/reviews/s...chnology-h-pas
SpecificationsType H-PAS, 2-way
Woofer: 5.25" (135mm) GLH
Tweeter: 1-1/8" (28mm) low resonance silk dome
Frequency Response: ~39Hz - 20kHz ±3dB
Nominal Impedance: 6Ω
Crossover Frequency: 2.1kHz
Crossover Type: Parallel, 2nd-order LP, 3rd-order HP
Sensitivity: 89dB
Recommended Amplifier Power: 20 - 200 Watts RMS
Dimensions w/grille: 8-3/4" W x 15-5/8" H x 12-1/4" D (222 x 396 x 310mm)
The prototype of the new Atlantic Technology AT-2 is less than 16 inches tall and has an interior acoustic volume of less than 2/3-cubic foot, yet it delivers full, rich bass response down to 39Hz at -3dB.
The prototype version of Atlantic Technology's upcoming AT-2 bookshelf loudspeaker uses a single 5-1/4" long-excursion woofer and the same 1-1/8" Low Resonance Tweeter (LRT) used in the AT-1. It has a crossover frequency of 2,100 Hz, which is much lower than most conventional two-way speakers, affording much wider horizontal midrange dispersion. The cabinet dimensions are just 8-3/4" wide by 15-5/8" high 12-1/4" deep (222 x 396 x 310mm).
No pricing info yet but these look interesting
Sensitivity: 89dB
There is nothing FULL and RICH about that bass design compared to LMS 5400 with 4000Watts in a 3 cuft box
