AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Hiqh Quality Macbook Mini-Toslink to Toslink Cable
post #1 of 4
I've been searching and searching high and low for a high quality glass fiber Toslink cable (to Mini-Toslink Cable) for my Macbook Pro's 3.5mm optical adapter port. At the moment i'm using one from a discount retailer but with my recent upgrade in stereo components i'd like to consider purchasing one of higher quality. However, i've been having a really though time finding a true Mini-Toslink to Toslink optical cable. They all seem to be either really cheap in construction or only come in Toslink to Toslink termination.
My other option is to go with an adapter but in my opinion that's defeating the purpose of buying a quality cable. I know there is a retailer in the sales forums offering cables that would fit my needs but wanted to see if anyone else has had any luck with finding a cable to suit this purpose.
post #2 of 4
Just curious... What exactly will this "high quality glass fiber" give you that you don't have now?
post #3 of 4
This should be good.
post #4 of 4
If you feel that there is a difference, purchase a bunch of cables, a Toslink to Toslink mini adapter, and then write a review. Post your review here.
Currently, it will take a good deal of credibility to pioneer the fidelity of fiber optics in sound playback.
