I am buying a wired playstation 3 controller, and I need to know what kind of USB extension cable to get. Do I need a female to male one? Or just a normal one? I mean one end of it has to be the whole where the USB cable from the PS3 plugs into, and then the other end has to be the actual USB thing same as on the ps3 controller, to plug into the console. So what's that called? Normal USB extension cable or female to male or what?
Is this what im looking for?
http://www.amazon.com/Foot-USB-2-0-E...5661981&sr=8-1
This more expensive one? http://www.amazon.com/gp/product/B00...A1SHTSJSJQA89P
Is there any difference between the 2.0 one, the more expensive one, and the less expensive one?
Thank you for your help
