AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Need Metal Pegs/Dowels For Cabinet
post #1 of 4
I just purchased a used TV cabinet for a plasma that I recently bought and the metal pegs that hold up the shelves are missing can anyone point me to where I could possibly order these here in the states. These are the pegs that fit in the pre drilled holes. Thanks.
post #2 of 4
Welcome.
You can get these in any HD or Lowes. Make sure to measure the diameter of the hole or the existing pins since they do vary in size and finish. or you can get them here.
http://woodworker.com/brown-plastic-...tm_medium=feed
post #3 of 4
Be aware that you need to measure accurately. 5mm and 1/4" are common sizes and are close enough in size to confuse if you don't measure accurately. Should be lots of places to buy locally. If you want to order on-line, same thing goes. Here is one place.
post #4 of 4
