Hi folks I need some help. My Pioneer 1325, that I have owned since March 2011, has in the past two weeks been going into shutdown while playing loud parts of the blu-ray discs. The red light above the ipod/iphone icon blinks continuously but no message comes up. After reading the manual, noting the suggestion that I check all the speaker connections - done and they appear to be fine – the manual suggests I take it to the repair depot.
I was doing so – here in Canada, it was through my retailer, Future Shop – I purchased a replacement loaner, in this case a Pioneer 1326. Hooked it all up and played another blu-ray Mission Impossible 4, and the same thing happened. It would therefore seem that it is not the receiver, but I have no idea.
The speakers are all Paradigm: Fronts Monitor series 7 and CC 190 (two years old), the rears are old Titans and the sub is a new DSP 3200.
I am now wondering:
1) The impedance is set to 8 ohms. All of the paradigms have the statement – “Compatible with 8 ohm”, does that mean I could set the system to 6 ohm and they would work?
2) Should I still take the A/V Receiver in to have it checked out?
3) What do I do to check out if one of the speakers is shot?
If anyone has any suggestions as to how to address the diagnostics of this problem, I would be very grateful. It’s driving me crazy.
I am now wondering:
