As long as I can disable it, I guess. I'd prefer a 120Hz display without it, but you can't find that nowadays.
It's impossible for interpolated frames to be of the same quality of real frames, and since even a single frame of different quality looks terrible (e.g. keyframe pumping) so MCFI also means that non-interpolated frames have to be degraded to match interpolated frames.
The only real solution to 24p is for filmmakers and disc makers to use a higher framerate. We don't need to give studios even less reason to stop overcompressing TV and lowpassing everything.
And I say this as someone with an rather high flicker fusion threshold (I've never seen a DLP without rainbow artifacts, nor a plasma without flicker and yellow flashes from phosphor decay.)
