I have to find a way of attaching a DIY screen to the floor and ceiling of our home theatre as it cannot be attached to the wall.
It has taken me 3 years to get rid of the damp problem we had in our semi-underground home theatre. Eventually, we paid a king's ransom to have the surface removed and a new surface plastered onto the brick walls. A special, cement-based product from Cemcrete (in South Africa) reacts with the moisture in the wall and creates waterproof crystals throughout the structure. It is a permanent solution but it does take time before the walls dry out.
The problem is, one cannot drill holes into any of the waterproofed walls, so I have to come up with a design for a sturdy, inexpensive screen framework that is bolted only to the stage floor and concrete ceiling. Any suggestions?
