Originally Posted by hordeall
about to pull the trigger on the 8350...
I need help deciding on mount and screen color.
Its for a finished basement which would be mainly used for movie watching and watching tv usually without much light (can be bairly any if not zero if wanted).
The ceilings are 10 feet high and white.
Walls Beige.
Throw is 14 feet if wall mounted.
Throw 12 feet at best if ceiling mounted (due to lower ceiling beyond that for conceiled duct which I dont think could be mounted to)
I wanted to keep the budget down on the screen.
I can get a Elite Ezframe White 1.1 gain 100" screen for around $250 and wondered if I should go with this or get a grey colored/different brand screen if this isnt that great of a choice.
Also, would it be best to wall mount or ceiling mount the projector in my situation?
And if ceiling mount is the best option what is a good cost efficient ceiling mount for this projector?
Walls Beige.
I would personally wall mount from that distance. I continue to encourage people who are sitting 12' or more away to go at least 120" on the screen. If you have reasonable light control, I would go with a 1.0 gain white screen, and I would consider the less expensive Elite Sableframe series in that case. Sableframe uses the same screen material as the ezframe, but it is only available in 1.0 gain white. The frame has a different profile, but is sturdy and about $100 cheaper in 120".
You might also consider the jamestown screen which is currently getting good reviews from members.
. Thanks for pointing that out.
... what to think. I saw the 8350 in action in a poor environment so it was hard to tell. What do you think here?
