Originally Posted by
MississippiMan
If the problem is due to inadequacies inherent in the HDMI cable's ability to pass a signal down such a long length, amplification will only "enhance' the video noise. If the cable is 22 gauge - v1.4 rated, the issue is most likely tied to the Amplifier and/or the output signal itself.
rakstr
I myself have not found that the signal strength reception of the 8350's HDMI intput is in any way weaker than, or not equal to that of similar machines. (...did you try switching to the other HDMI input?) Was your previous display 1080p?
Yes, I've tried both inputs.
Funny about the question on two disti amps. I broke down and ordered another HDMI capable receiver so I'll now be reworking the wiring and may have to try amp-amp at this house as well. I really need to get another input setup so I can test out thoroughly for the video drop before my exchange window at Fry's closes. Unfortunately, I'm getting convinced it's the PJ
I found my stand alone ATSC tuner (things really get hidden when you move) and I'll get that hooked up before tonight's Rangers game.
For the other poster, I've done this before at my previous house without issue BUT you need to be careful on over-amplification and all the other issues you have just like when you begin to daisy chain any other devices like when running RG6 for antenna! When I did it before, I had a 50ft run between amps (Monoprice CL2 22g). The Disti Amps were Monoprice HS-104. The specs say this is AOK. I think their math is wrong however on the number of HDMI signals at full deployment (3+3+4=10)
Supports high-resolution video - HDTV resolution of 480p, 720p, 1080i and 1080p (1920x1080); VGA, SVGA, SXGA, UXGA (1600x1200), WUXGA (1920x1200)
Cascade distance: Source to Device -1.8m,
Device to Device-15m,Device to Display-20m
Supports 12-bit Deep Color for HDMI formats
Cascadable to 3 levels - provides up to 8 HDMI signals.
Long distance transmission - 20 m (24 AWG HDMI standard cable) and 15 m (28AWG HDMI standard cable)
DDC compatible
HDMI 1.3b compliant
HDCP 1.1 compliant
Signaling rates up to 2.25Gbits in support of 1080p display
All-metal casing
LED indication of display devices
Plug-and-play - no software installation required
