Just thought I'd give some quick feedback on the projector on the off chance it might help anyone.
I was in the same boat as many a few weeks ago - trying to decide between the 8350 and a few other options. I had narrowed it down to this and the AR100U, because I was worried about brightness.
My thoughts so far:
- LOVE this projector
- It does fine with ambient light, and even with a few windows open. Based on the fact that the picture quality is supposed to be better than the AR100U (black, etc...), I'm very glad I didn't sacrifice. For me, the night time movie viewing is the most important and where I want the projector to be at it's best. The daytime stuff is nice, and the 8350 is fine in this regard (especially for sports which is a bright picture to begin with).
- It's quiet, which was a big concern of mine. It literally sits a few feet behind me, and I don't notice it.
- The sharpness and quality of the picture continues to impress.
- The zoom and lens shift are a HUGE plus. Would hate not to have these
- I often view 130+ inch screen, and it looks good
- The blacks often aren't "velvet black", but still very good considering. And I'm only projecting on an off-white wall.
BIGGEST LESSON: Screenshots on AVS don't mean all that much :-). I say that only because I looked at a million of them before buying, and I know others do too. They can help somewhat if you take them with a grain of salt, but I can tell you that moving my camera up or down and inch dramatically changes how the picture looks (contrast, color, etc...). And because of the nature of a moving image, a pause screenshot picture will look sharper than watching it live (I say this because it lead to a little bit of a let down with first watching the projector until I realized the reason).
Another reason I mentioned the screenshot issue is that I almost didn't get the 8350 because some of the screenshots I viewed in the "screenshot wars" thread didn't look as good as a few of the other models. I laugh at that now.
I think for now I'm going to go without a screen because i really like the option of adjusting depending on the content (sports vs movies vs aspect ratios vs ...)
In the end I think it was the perfect mix of picture quality, brightness, bulb life, support (so I'm told), and flexibility.
Originally Posted by
Carlos_
Hello.
I am a projector newbie.
I am considering purchasing this projector.
One of the complaints of people who have this projector is that it does not transmit very black blacks.
My question is the following:
Will the blacks that this projector is able to transmit get better and increase ( or if not increased be perceived by the human eye as being more black) as the size of the screen gets smaller?
I am considering 3 different screen sizes: 120 inches, 106 inches, and 100 inches.
Assuming that the projector is placed in the same location at the same distance for all three screen sizes, ( i believe about 15 feet) and in total darkness, which screen size will have the better black levels?
MISSISSIPPIMAN feel free to chime in. I believe you mentioned something about this earlier in this thread. Thank you.
I wondered about this, and indeed the blacks do get a little better as you make the picture smaller, but then again the quality of the entire image gets a little better is you make the image smaller. However - my experiments were going from 130+ to maybe 70-90ish, so might not be applicable to your question.
I don't think black levels will be different enough to justify deciding on any of your possible sizes. You probably won't be able to notice a difference.
What I would
STRONGLY suggest is you get the projector first, play with the sizes on a blank wall, and then decide on your screen size.
