Try the Blu-Ray player again, directly to the projector (no amp).
What is the make and model of this cable? What is the gauge?
I read what is says (about 28awg being fine) and maybe it is (since the Blu-Ray player plays fine over it). Maybe it's magical or special, but since it doesn't work with the amp you have to wonder about it. I don't think they sold those back when I bought mine. Maybe RedMere is not compatible with Yamaha HDMI or you have some other problem. I know a little about electronics and signals. Maybe it's old-school, but I think I would have still bought what I bought. Normally, you increase gauge as length increases.
If you would have asked first, I would have suggested something much thicker. It's been asked before in this thread and thats what we (I anyway) told people.
Sorry to hear you are giving up. It's not that hard, but you certainly have had some bad luck on your install.
Connect XBox360 directly to 8350 and do your res thingy. If it doesn't work over 30ft-RedMere, try 10-15 ft normal cable (bring xBox to projector). Find out what works and troubleshoot from there.
We watched Ghost Rider 2 tonight. Nice special effects (fire it not easy to CGI). Scenes were dark and we saw no banding. Still need to double-check those scenes you mentioned again (give me a few more days). Exact movies and time would help speed things along.
Well, there are lots of color settings in the 8350 also (as i said). Get PDF manual and seach "color". With 10-bit color and over one billion colors, you shouldn't be getting banding.
Set PS3 color bit level as high as possible or deep color on.
Ya, another component that will play Blu-Ray (perfectly) would be helpful right about now. Blu-Ray players are cheap. I think a Sony 590 is $100. Take it back if you don't like it. Or, you could borrow one.
Not sure I understand ...
If you are doing OTA ... ATSC with antenna, you might as well get a nice one of these:
http://www.avsforum.com/t/179095/the-official-avs-hdtv-stb-synopsis#post_22779649
Free ATSC is actually pretty good with a good antenna and enough signal.
If you just have analog cable? Well, for what you are paying, it's probably like $10-$20 more to get a digital tuner ... go to the office and get one.
I think you can also get rent a Cable-Card for the TiVo but I have no experience with that. Check their forum.
Yes, please check your manual. Lots of good stuff in there.
Since my room is multi-use I use 3 different Color Modes. I use the darkest one at Night and the next 2. I could check their real names if it's important. I called the marcos on the Harmony remote Night, Dusk and Day. I've never noticed any banding and most Day viewing is instead on the plasma.
I'm pretty sure only the Power Consumption option (Normal or Eco) affects bulb life. Maybe someone else knows for sure.
Right ... you are using the digital tuner in the TV to receive the ClearQAM digital channels. This is a side-effect of having analog cable. Pretty sure ... if you (anyone) have the cable connected to your house, you have analog cable. They can't disconnect it because you are using their Internet service.
I think we have covered your options pretty well by now.
Good to hear you are finally able to use your 8350. What exact cable and gauge did you end up using? You might be able to return the RedMere to MonoPrice.
Once you have the cable working external, it's not that much harder to install in ceiling attic if you are handy (eventually ... not now ... enjoy some first). Also, concider just going ahead and use a proper ceiling mount (you "get back" some cable length).
Saw this a while back:
http://www.avsforum.com/t/1280137/the-offical-epson-8350-owners-thread/3360#post_19988371
However, if your existing shelf mount is mounted and working in the proper place ... I would just tighen it or wedge something in the hinges. You can do good things with wire-ties and pieces of plastic lids.
