Let me know when you get Avatar, I'll swap you 2-1 (Last Air Bender/Cloudy with a Chance of Meatballs) for a couple of weeks if you are game.
The first day I did the Picture wizard to set it to what I like the most. I noticed the led dimming in dark scenes right away. Like little flashlights in the sides of the screen Very distracting. Its a very good picture quality as long as there isnt the widescreen dark bars omn the top and bottom like most movies have. I tried to use trumotion on rockband , it has its ups and downs. The characters looke crisp and smooth. but the falling notes are all studdering and lacking framerate but only when theres a bunch of notes...? if its like 2 or three notes dropping the Tv processes them smoothly and clean. I tried the 3D with Cloudy with a Chance of meatballs Bluray 3D. It looked good for some parts. But the crosstalk was really bad in alot of scenes. I tried my ps3 demos / games in 3D and the cross talk was still present there too. I decided a couple days later that im gonna return it back to Conns and just purchase a Samsung for more, being that Ive seen and heard that Samsung have far less crosstalk. But when I called to see their policy on returns they charge 15% restocking fee which basically makes it around 300 bucks they get from me, just because I wasnt satisfied with the tv. what can i do? I cant decide if I should lose my money and spend more on a different Tv, or just sit on this and see if it improves with the firmware updates (its updated twice now its version 04.10.08). Even with the updates the 3d hasnt really improved THAT much that ive noticed. I have 30 days till im officially stuck with it.
Thanks for that report, not surprising unfortuntely, I guess we all were hoping otherwise, at least you tried. I will contact LG and/or my extended warrenty provider (bought through Future Shop) and see what they tell me. I will tell them this is not acceptable and would like to replace my TV or fix it.
From both remote possiblities, I think replacing it is probably more likely than fixing. Gabriel, little older and wiser, |
