AVS › AVS Forum › Audio › Speakers › Polk Atrium 6,7, or 8SDI vs Definitive Tech. AW5500 or AW6500 to use with SONOS
post #1 of 6
Hi, I am looking for some outdoor speakers to setup with my Sonos. My sonos has a built in amplifier that handles 55 Watts RMS per channel. I have been looking at some speakers for outdoors but I can't decide either going with Polk or Definitive Tech. I know DT makes the legendary Mythos so they have good feedback and I have always heard Polk makes good speakers too. The thing I can't decide on is if its worth paying extra for bigger speakers. For example, The DF AW5500 are rated from 10-175 watts while the Polk Atrium 6 are rated at 10-100 watts. Will I get more sound using the DF AW5500? For this example they both are the same price. But I want good quality speakers. Likewise the AW6500 are rated 10-200 watts and the Polk Atrium 7 are rated 10-125 watts so I really can't decide which is best. Keep in mind that the Polk Atrium 6 pair is 400 dollars so is the DT AW5500 and the Polk 7 is 500 dollars the pair so is the DT AW6500.
post #2 of 6
I sent you a PM regarding some Definitive Tech. AW6500's
post #3 of 6
I own a pair of Polk Atrium 55 and I'm a bit disappointed about their sound quality. I own quite a few Polk speakers, and I love them all except the Atrium. There is no bass, and the mid-range and highs sound pretty thin to me.
I compared them side-by-side with Polk R15 bookshelf, and both me and my wife feel that the R15 beat the Atrium 55 hands down.
I love Polk speakers and have recommended the Polk monitor line to most of my friends who want to build a budget system. In my opinion the monitor 50s are the best price/performance that you can find out there if you are on a tight budget, and they are the best entry level system. However, the Atrium 55 really disappoints me.
post #4 of 6
I bought refurbished pairs of Atrium 60s and Atrium 65SDIs from Polk's eBay outlet site for $160 + $20 shipping and $175 + $25 shipping, respectively. (Mine are white; black usually sells for less.) They both sound absolutely fabulous with great highs and lows.
As I said in another thread, both pairs arrived in boxes with a sticker indicating they were refurbished. I have to believe them but, I couldn't find anything else about these speakers that would suggest that they were anything other than brand new.
If you're looking for quality outdoor speakers with ~6 ½ woofers, this is a seriously great deal. - I love the speakers and I love the price!
post #5 of 6
Originally Posted by TheWind View Post
I bought refurbished pairs of Atrium 60s and Atrium 65SDIs from Polk’s eBay outlet site for $160 + $20 shipping and $175 + $25 shipping, respectively. (Mine are white; black usually sells for less.) They both sound absolutely fabulous with great highs and lows.
As I said in another thread, both pairs arrived in boxes with a sticker indicating they were refurbished. I have to believe them but, I couldn’t find anything else about these speakers that would suggest that they were anything other than brand new.
If you’re looking for quality outdoor speakers with ~6 ½” woofers, this is a seriously great deal. – I love the speakers and I love the price!
Thanks for the info both of you. I see they are a good price but I am not looking for the best price I can find. I am for the best sound out of these. I really want to thank you for the suggestions but I want to know if I should go for Definitive Tech or Polk's new series. I want to know if a speaker rated to a higher watt like the definitive tech rated to 10-150 will sound louder with the 55watt rms per channel from the sonos rather than the polk rated only up to 100.
post #6 of 6
No, that's not what those numbers mean.
Those numbers represent the manufacturer’s determination of the minimum watts required to drive a speaker and the maximum watts a speaker can handle before exhibiting serious, or even terminal, problems. – Be aware that although it’s certainly possible to break a speaker by feeding it too many watts, it’s also possible to break a speaker by using an underpowered amp and turning the volume control way up in an attempt to increase loundness.
It's the “Efficiency” of a speaker that is a measure how loud a speaker will play on a given amount of watts. The higher the “Efficiency”, the louder a speaker will sound at a given wattage.
  Back to Forum: Speakers
