AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › The Ultimate 3D projection system: A Practical Discussion Thread
The Ultimate 3D projection system: A Practical Discussion Thread - Page 47
post #1381 of 2106
Originally Posted by sorini View Post
My screen will be large enough in diameter 240 inch.I used the calculator to projectioncentral.com, and for 240 inch diagonal image must use the maximum zoom 2X and projection to be made from 7 meters. You have smaller size filters to your projectors?
Yes, I have the smaller variety. 35 x 47 (actually it's 55mm). I tried to measure the image projected on a paper at lens but as you can't focus at that close range I cant do a health measurement. So I am really not sure about this.
Also, at 240" you would get a pretty dull image. less than half of what I get from my projectors according to projectorcentral.
post #1382 of 2106
Hello rdjam. Can recommend a HDMI 3D splitter FULL HD. From 3d blu-ray player to bring 3D image to the 2 units OPTOMA 3D-Xl?
I've found that most of the cheapy HDMI 1.3 splitters seem to pass the signal just fine. Was looking for an HDMI 1.4 splitter in the beginning but gave up.
To be safe, just look for one that claims compatibility with 3D signal pass thru.
post #1383 of 2106
Originally Posted by wnielsenbb View Post
Not sure at all what is being talked about there.
I see the desire for a modulator. Easy = good, usually. Stacking projectors is scary. This is why LG went with the approach they did with the passive CF3D. They put both projectors in one box. They just made it way too expensive. The modulator doesn't allow gaming at 1080p 60 per eye, and still has the flicker problems of active, and is too expensive.
Someone just needs to come out with a box containing two projectors with a single output lens. The savings on the second lens should pay for the extra mirrors to unite the projector images. It should cost around 2k since the projectors we are talking about are 1k. Throw in the dual 3DXL's in the same box for another 600 and you are less than 3k for a great passive 3D system.
...but they haven't yet
That's why we are building out own dual projector stacks with our own choice of remix and processing.
It makes for a hugely flexible and powerful 3D display system, that will be upgradable.
I too would prefer to find a dual beam passive system like this off the shelf and affordable, but it doesn't exist sadly. Only two systems that were close were the LG and Runco. The LG has a couple compromises but decent price, and the Runco is pricey... Very.
A new specialty 3D demux unit will be out shortly that will be demuxing 120hz Nvidia 3D vision. A quick change of connectors and I'll be gaming at 1080p60 per eye.
post #1384 of 2106
Do you have more info you can share on the demux unit that will work w/ 120 hz 3Dvision?
post #1385 of 2106
Originally Posted by yunti View Post
Blackshark I've been using 3x active displays for 3d vision surround for a while so I forgotten the various options for trying to get gaming working in dual display. The details in your thread in 3d mtbs forum seem slightly out of date now
I think you had a more up to date thread (was this in French?) that covered the various options but I can't find it
I'm not sure if dual projection is an option on nvidia cards unless using ddd drivers (do they have dual projector support)
What games have you managed to get working? Do all amd hd 3d games work easily?
I don't have a French equivalent to my dual-projector thread, I only have the thread down here in my signature and a copy of that thread at MTBS3D forums (where other people from MTBS also participate)
The French thread I often visit is a generic "any kind of 3D" thread at hardware.fr forums, but there aren't any extra information you won't find here.
I do need to rewrite my 3D projector thread, probably from scratch since so much stuff has changed since I originally wrote it :
-I now have better knowledge about polarisation
-I now have better knowledge about projectors in general
-I now have 2 different types of polarising filters and am about to get the Omega filters
-I have stumbled upon Eyefinity bugs, found their source and work-arounds
-The thread misses information about the iZ3D driver special configuration to get the side by side Eyefinity mode running
-I have just bought DDD Tridef drivers (yesterday) and they support side by side Eyefinity mode directly using both the traditional dual-outs mode and the side by side output.
I'll wait to get my hands on the Omega filters and test them properly before I start actually rewriting my thread.
Dual projectors with Nvidia cards ?
You won't be able to use the side by side mode since Nvidia mandates 3 displays to use the surround mode, but you'll still be able to use the traditional dual-outs mode (but you won't get frame lock).
Both iZ3D and DDD drivers have dual outs support working with both GPU brands.
A few games (Avatar and Crysis 2) also support dual-out stereo.
HD3D ?
AMD HD3D supports Hdmi1.4 and DisplayPort3D displays only (and also one Dual-link DVI display). Dual outs are not supported.
I don't have Optoma 3DXL boxes so I cannot test HD3D.
Games I've played on the dual projector :
Just about any game working with iZ3D and DDD drivers work with the dual projector using the side by side dual-outs mode.
I encountered a few bugs with some games using the iZ3D driver because the side by side Eyefinity mode was beta feature and the driver is no longer updated (for example the mouse cursor is broken in 50% of games), so far for the games I have tested the DDD driver is working just as well as any other type of 3D display.
Most games with native 3D side by side mode can run the projectors but the aspect ratio will often be wrong. Although I did get some surprises :
->Avatar : the game config file has plenty of options to adjust aspect ratio but they don't work with 3D (no good)
->Crysis 2 : there is no aspect ratio setting (no good)
->Sonic Generations : When activating 3D, the game assumes you have a 16:9 display no matter what the internal render resolution is (lucky game ! render 3840x1080 and it works)
-> Trine 2 : You can tweak the settings file so that the game renders at higher resolution and resizes the side by side picture at the proper aspect ratio (not optimal but works).
If you go for dual-projectors, I still recommend to take BOTH drivers, because some games still work better with iZ3D than with DDD (like Dolphin the Gamecube/Wii emulator). And I noticed that FPS performance was significantly better with iZ3D on quite a few key games I play.
post #1386 of 2106
Originally Posted by digitalsleep View Post
Any updates on that edge-blending demux super box you posted?
I am curious too! Please give us your plan.
post #1387 of 2106
ive found they can be had at least. in low quantity ~1k higher qty ~ 500 but i have to see what we are going to offer. not a bad price even if we need to go 1500 considering it can do demux, scaling and edge blending for two units all in one box. i think the box pteradactyl is working on is similar and will be competitive.
post #1388 of 2106
They seem to have two boxes capable of demuxing 3d. The 501 and the 502 which has quite a few more features. Was your quote for the 501?
post #1389 of 2106
the quote was for the 501, the 502 is not supposed to be a lot more and i heard there may be a cheaper alternate they will have as well. it really depends on the quantity one can purchase at one time. most of us dont need what the 502 can do but the idea of using a curved screen for gaming is very interesting.
post #1390 of 2106
Pterodactyl has been discussing a box he is working on over at http://www.avsforum.com/avs-vb/showt...1257435&page=8
I would still get a 3DXL in the meantime if you are looking to get started, as I don't know much about the full details on the capabilities of the box they are working on.
But it looks very promising for 1080p60 per eye gaming with a standard NVidia setup.
I just got 2 x GTX 680 cards this morning. Was very lucky - they are selling out fast.
post #1391 of 2106
That sounds great motorman - will your box be able to demux NVidia 3D Vision 120hz? ie to output two 1080p60 streams, one for each projector?
post #1392 of 2106
Exactly what I'm keen to know as well (but it doesn't look like it from what I could read on the specs)
post #1393 of 2106
(you really do seize the moment rdjam -well done). I'll probably mull it over for a few weeks before ordering
The new features with the latest nvidia cards look like they could help those with a dual projector setup.
As blackshark mentioned this was difficult with previous nvidia cards
The new nvidia cards have new multi screen modes and these support upto 4 screens on one card. However I can't tell from the info so far whether this works like AMD's eyefinity. However from Nvidia's website it does also mention that you can also now "define whether application windows should be maximized across all displays.". Not clear if that is quite what is needed or not but there is more info here:
http://www.geforce.com/whats-new/art...rce-gtx-680/#1
Potentially this could give another option for those using dual projector and just wanting to display films. However for gaming it looks like we are still stuck with the DDD or iZ3d options blackshark mentioned earlier. And the best option seems to vary from game to game. This is where if there was a box to make dual projection work with standard 3d vision mode it would be so much easier.
(also thanks for your post earlier blackshark. Would love to see an update of your thread with your latest impressions. Ps did you mean you had the 7970 I thought the 7990 isn't out until q2 )
post #1394 of 2106
Damn and I just installed a 2.5GB GTX 570 (first of 2)... I didn't even realize this was about to come out... 3D vision surround on one card!?!? I wonder if there's really anything different in the hardware to make this work, or if they just fixed the drivers (and yet will proceed to lock out this feature by detecting the older cards and disabling it, just to make more $$$ selling them in pairs).
That software fix is the maximizing windows fix, where they snap to individual screens instead of spanning all 3, a feature Matrox had in the Triplehead2go years ago (a lot of people were using the Matrox software to get around this missing feature in Nvidia surround).
post #1395 of 2106
Indeed I made a typo mistake. I have a 7970.
I am pessimistic about Nvidia surround support for dual projectors.
Nvidia systematically associate surround with triple screen, even in their hardware requirements they keep saying you need 3 screens.
They haven't updated their surround hardware requirement and supported resolutions page for their new 680 card yet, but from what they claim on the geforce 680 page, they're still thinking with the "it's made for 3 displays only" mentality : they even refer the 4th screen as an "accessory" screen (ie : you don't game on it)
post #1396 of 2106
To rdjam and everyone on here making this happen, thank you! Well I didn't really need a new project but with the Omega Kit it looks like I'm hoping to head down this road too. I've been through the thread and have some questions, sorry if they have been asked already.
I'm still a bit confused when it comes to all the parts needed to make this happen. It seems a few on here are very HTPC focused. While I will need to upgrade my HTPC at some point, I was curious how my current sources would work first.
I have the Panny bluray player (110), xbox 360, PS3, and a Yamaha 3d passthrough receiver along with a non 1.4 compliant htpc right now.
I think I can have the 360, ps3, and 3d bluray player stay where they are on the receiver? My chain would look like this.
(360, ps3, bluray player) --> receiver --> hdmi splitter --> 2-3DXL's --> hdmi out to projectors.
At the moment, will the above work without a PC in the mix?
Adding the pc into the mix, I have stereoscopic player on my current non 1.4 PC (Acer Revo) - It can handle most things I throw at it except 3d bluray. As stereoscopic player can sort of play 3d bluray right now with the SSIF files, would we still need a 1.4 compliant video card if going through the chain above?? Also regarding the computer, it seems that with the right video card, you could possibly skip the need for the 3DXL's? Just confirming if that is true but the 3DXL's seems like a great 'catch all' solution with or without an hptc.
I read in the thread somewhere that the 3DXL was only doing 720p, but I think that is for gaming systems only, is that correct?
PJ's I'm considering need to be CIH with a very short throw (10'6" lens to 88" wide 2.35) as an extra variable. I am researching them more at the moment, any comments on the PJ's below for this setup are welcome. My biggest concern for the following projectors is that a true frame interpolation method is not present. This is my budget however. Can anyone comment on the fake CFI for the panny (smooth motion?) or others??
Viewsonic Pro8200
Panasonic PT-AR100U
Benq 1100 and 1200
Epson 8350
Currently I'm using Cinemavision 1.3 screen. Glad the Omega filters do away with most things in relation to light polarization, can't wrap my head around all that just yet!!
Thanks again everyone for this thread and looking forward to some input on my specs before I jump in with both feet!! The wifey is going to kill me during the process but I'm sure she will love the end product
post #1397 of 2106
On the non pc setup you mentioned that's fine. You may not need the splitter if you can use 2 outputs on your amp.
The 3dxl's do convert the HDMI 1.4 spec 3d signal to the dual projectors and can do this at 1080p 24hz. Used as a single box they will convert the frame packed signal from your source to page flipped for the 720p active 3d projectors that can only accept page flipped only such as acer 5360 (this feature isn't relevant here unless you want active 3d and have one of these projectors)
Yes you are right if you are happy to play 3d films from your pc then you wouldn't need the 3d xl boxes
If your budget is limited to non FI projectors then this could be done on the pc as well. Several options to do this but one would be the smooth video project. http://www.svp-team.com/wiki/Main_Page
post #1398 of 2106
smooth video project - that seems interesting, and this would work with 3D Bluray? I'm not a huge gamer, wondering now if $800 would be better spent on the 3DXL's or a new PC build. New PC build would also be game capable. I like the ease of the consoles and the fact you can't waste too much time tweaking lol. hmmm
Thanks for the response.
post #1399 of 2106
J&R is offering the 3D-XL unit for $299US (price includes a $29 built in rebate) through March 31 for those that might be interested.
http://www.jr.com/optoma/pe/OTM_3DXL/
post #1400 of 2106
I've also seen them as low as $250 without the glasses, Tru3d has them for $260 right now. If you only plan to use them with dual projectors get them cheaper without the glasses!
post #1401 of 2106
looks like i may be able to offer the geo 501 box with the omega filter set and glasses but ill have to see if its going to be cometitive with getting the two 3d xl boxes and a splitter. i really need to get one and test it out with a blueray player, a playstation and a pc that had hdmi output. i also need to get two better projectors than i have as well. i may be able to find a projector pair to package but that is harder as the set must be appealing to a range of people.
post #1402 of 2106
what do you all think about a curved screen with HD 3D capability ? i want to see if i could get a geo502 box and 2 pairs of projectors and a curved screen for a project and use edge blending and well as distortion adjustemnt for this wide curved screen app. mostly for gaming but movies would look pretty awsome i think. kind of expensive i know but immersive ?
post #1403 of 2106
Viewsonic Pro8200
Panasonic PT-AR100U
Benq 1100 and 1200
Epson 8350
Yes, your chain looks fine, and you can achieve 1080p 3D from an appropriate source like Bluray 3D - but you will have to obtain an HDMI 1.4 receiver that allows 3D frame packed like Bluray to pass through.
If you're using the Omega filters, I recommend you focus on big light, as the bandwidth filtering will cost you a lot of brightness. Also, if you can swing it, go for the larger Omega lens (the one that ships with 10 pairs of glasses) - I feel it will be much easier to use and make your life less complicated.
I hope you're able to find something that does do the frame interpolation as it really truly makes a huge difference in the 3D experience.
Haven't seen the Panny FI in action, but I was under the impression that they had a true creative FI systemic their projectors (just not on their plasma TVs).
I've also been Bluray centric the throughout this experience. Only now looking to get a 3D gaming system added to the mix. I'm pretty confident I'll find a reliable way of making it work in the next few months. Decided on the new NVidia card as they seem to have better 3D support from the game studios, and I'm looking to say away from "tack-on" solutions such as Tridef etc.
Pretty sure I'll be able to make something work at 1080p60 per eye.... Hopefully!
post #1404 of 2106
Why would you want it any other way.
And is there any other comparable way.(4k blu-ray aside)
post #1405 of 2106
So 4 projectors with some kind of curved screen that supports 3d. I think it would be awesome. Will be noisy and expensive but sounds intriguing.
post #1406 of 2106
I'm thinking of doing the same with four 720p LED projectors using 3M Vikuiti rear screen film
http://www.youtube.com/watch?v=Ce3Jf4n7R14
post #1407 of 2106
yes its a great idea. here is what im talking about but with my passive 3d as well
http://www.youtube.com/watch?v=JsUkwgyxyXY
would be noisy but who would notice while gaming
post #1408 of 2106
Very very interested it that. I have been running a 3 x active 3d projector setup for a while now and the triple screen at the size of a projected image is easily as important for immersion as 3d. However i only got that setup as a temporary solution as I'm very keen to change to a passive setup with 6 projectors. However there is no driver option for that at the moment although I have been pushing for pterodactyl's box to include a page flipped to dual projection convertion option which would make it possible. (this would make nvidia 3d vision surround work without any hacks) I briefly thought the geo boxes you mentioned would solve this but it appears they don't have that option. The edge blending and distortion adjusments are definitely useful features for me too. I have only evaluated a software based solution up to now.( I wasn't aware there were hardware based options for this)
post #1409 of 2106
And having lots of projectors close together to line up on a curved screen gets seriously hot too!
post #1410 of 2106
the geobox 502 can support multiple sets like the 3 pairs your talking about. at least from the pdf they sent me. edge blening and distortion and multiple outputs with splitters. i will try to find the pdf and post it next week.
