Originally Posted by
jmcguire525
I think we should all email them encouraging them to build this, I just want something similar to two JVC's built into one box with a high lumen LED light source.
-LCOS panels (or anything that will give us great contrast)
-LED or Laser light source (seems like LED would be best for Omega)
-Simultaneous L/R 3D using Omega filters
-CFI for each L/R image at 120hz
-Compatible with A-Lens for scope 3D movies
As at this moment, two JVCs and a polarized setup are getting me excellent 3d, with superb brightness and color quality, as well as a great contrast ratio.
I suspect that if you want extreme extinction with color filtering, you must have good light canons as your source.
No question, when I upgrade the system for my new room I'll be doing the light cannon thing. But for now, this is what I find works best on the whole.
The experimentation in this thread is excellent, and one must always stay open to all options. However, bear in mind that some options are better suited to certain situations.
I'll have some more objective numbers when I play around a bit more during the week.
I think the best way to illustrate what I'm seeing is with stereo photos. The kind where you cross your eyes a little and see 3D. So I'm doing some test shots to see how I can put those together.
