I'm pretty sure that rdjam's reference to the "ultimate" projection in this thread is nothing other than the fact that passive projection is in most cases can be better than an active solution and what it takes to achieve it in the home.
rdjam states on the first page of the thread........
"THIS THREAD, is for anyone interested in the subject, to add their thoughts, experiences, and also source materials they have found.
At this point in time - the system I am visualizing will result in a 3D home theater with the following attributes:
(1) A discrete two projector "passive" 3D system, which allows the use of cheap, "passive" theater-style glasses, rather than expensive "active" shutter glasses.
(2) Light output of 96 hz or 120 hz per eye (depending on content) rather than 24 hz, 48 hz or 60 hz of most existing solutions
(3) Frame Interpolated output for each eye, resulting in a higher TRUE frame rate for each eye than source 3D material commonly available. One of the bigest bugbears I have with 3D films now is that a low frame rate is more disruptive to immersion in 3D than in 2D.
(4) A system that will handle all available 3D formats, not be restricted to a particular set of standards of the particular projector used.
(5) A system that will allow you to use regular non-3D projectors, even of disimilar resolutions, to make the 3D theater.
(6) System that allows use of picture enhancement technology that is not currently available for 3D use. For instance, I plan on intergrating two DarbeeVision boxes to enhance the 3D impact.
As they said in Inception "You mustn't be afraid to dream a little bigger".
I repeat
I repeat
