Originally Posted by darinp2
My assumption has been that the glasses would block all relevant frequencies that are not meant to be seen and only allow things through that were meant to go through (other than that there is always some leakage). Are you saying that filters designed to go in the projector block frequencies that the glasses don't block and if so, I'm curious if you have a source with an explanation of what those are.
--Darin
--Darin
I'm guessing the glasses could be simpler than the projector filters. The glasses only need to block the three wavelengths from the wrong eye perspective. The projector filters need to block all wavelengths except the three for the correct eye. Using the narrow bandwidth projector filter for both the projector and glasses would of course also work. Don't know if that's how it's implemented though.
Using lasers or narrow band width LEDs with the right wavelengths as light source you wouldn't need any projector filters, as you say, and the total light efficiency should be really high.
Many reasons to move away from bulb based light sources.
) extra RS1x so i can just run an infitec setup again, if i could find a way to color correct infitec on my HTPC, it'be a no brainer for me, it's the one thing holding me back for searching for a second projector instead of buying a brand new RS40.
