Ron, thanks. Yes, Anssi is absolutely taking care of me. Replacement parts have already left Finland, arrived and departed Sweden and are on there way for Thursday delivery!! I'll save the full story for later this week but thus far I'd have to say this is the best service I've ever encountered.
Originally Posted by 230-SEAN
Another idea I have is to buy longer screws/bolts (not sure what is used on the lens) for the "legs" of the stand, that way the mounting is 100% hidden and would look alot more clean. I'm not sure if this is doable since I don't have a lens yet, ahem ahem, but it might be an option. Ron does your lift work? If so, what are your thoughts on it?
-Sean
-Sean
I would suggest that the single mounting hole would be fine if attached to a flat plate and well tightened. You could also fashion something to clamp onto the non linear motion (15mm) support. In my case I'm going to create an elongated 'U' mount that attaches directly to the ceiling and mount the lift inside. This way I can keep the weight off the projector mount.
) grips that the owner can affix to their existing PJ mount, similar to how they work for the CB-500 mount, or on the bottom of their mount. Admittedly not a perfect option since it throws of the the balance of the mount/PJ combo. But may be preferable where a separate ceiling mounted lens lift is not feasible.
