Originally Posted by
Verge2
Did you mean pixel size.
I see what you are saying. But considering these lenses cost more than almost all the projectors discussed in this forum, I don't see the benefit.
If you watch SD material and zoom on a 1080 display you'll see what I mean by pixel visibility - if you zoom it bigger, it becomes more visible, how visible and how much that becomes an 'image artefact' depends on the seating distance and projector technology being used. It's still an issue with HD and zooming (if you sit close enough), but it all depends on seating distance.
Not many people (especially those new to projectors and home theatre) realise how close they sit in a commercial theatre, and quite often sit a lot further back with their home set ups. THX consider a 36 degree viewing angle to be the back row (3.7 x the image height distance), yet many people sit further back than that. They're happy because the image is much larger than their tv, but they're still a long way back from the screen compared to the cinema.
In this forum I can see why some people would be against going for a lens (it can definitely a case of diminishing returns, especially if it costs more than the pj), but they don't have to be expensive if you're patient and look around on the second hand market. You can find some good lenses at good prices - I picked up an ISCO II for $800 in the classifieds here, and found one even cheaper on another forum in the UK. People tend to keep the lens and upgrade the projector if they have a good one (some lenses are better than others).
If you have a set up that you're happy with then that's great, but not everybody sits in the same place and/or has the same preferences. One mans meat is another mans poison.
Verge2
8500ub and a lens(and video processor maybe)
Or a higher end jvc for the same price. I know what I'm choosing. I will just mask the screen.
After going 2.35:1 I couldn't go back to 16:9, and after using a lens, I couldn't go back to zooming. Sometimes though ignorance is bliss - so if a lens is not on your list of priorities (and you don't sit so close that it's necessary), don't demo one, just in case you see the improvements and want one. I know a few people that's happened to..
Gary
