Originally Posted by mogambokhushhua
@signal 34
The TOSLINK switch will only switch audio...
you need to hookup all your video (DirectTV Box and blu ray player) to the TV
and then audio over optical to the toslink switch and the toslink feeding the 510.
also whenever you switch video you would also have to switch the correct audio input on the toslink switch..
Also for people with just two sources you can use this
http://monoprice.com/products/produc...seq=1&format=4
Even though its a 1 to 2 splitter people have successfully used it as a switch as long as the just one source is active at a time..
@signal 34
Many thanks for the info. I did look at that one, but went with a powered one that handles 4 inputs/2 outputs in case I get some more components in the near future. Got it for a great price on eBay.
But I guess I should have tried to make my question clearer:
Should I use run the Toslink from the TV to the switch, or the Directv receiver to the switch? Will I get better sound quality from the Directv receiver or TV, or is it a moot point since each can output 5.1?
Thanks for all the help guys....
for your opinion on how the soundbar sounds with the rear volume turned down..
