Originally Posted by
brian6751
i gotta ask, cuz i dont know and im looking to buy one of these for sub duty. Seems to be a TON of happy MiniDSP customers using these for their subs. Why has no one had issues like this till now?
Probably because we're talking test tones, not program material. A lot of things can be marginal on test tones, but utterly masked on real program material.
Aaron Smith
]The biggest limitation is they are only 2 in/2 out; whereas you can buy an 8 in/8 out MiniDsp for $399 plus whatever shipping is to the US (does anybody know what the average shipping rate is?).
Remember that the box is $100 or so extra, but worth it IMO because it has all the holes punched and looks pretty good.. (For multichannel audio use, there's no reason to spring for the 10x10HD, because its extra features aren't of use here. And screwing the board to the case is a 5-minute job even for a serious klutz.)
Shipping [edit]to the US at least[/edit] is, I believe, $25 flat rate no matter what you order. At least, they charged me $25 for my last order (8x8 board, their then-new case for the 8x8 board, two balanced 2x4-in-a-boxes). That was, if memory serves, late last spring or early last summer.
And keep in mind that the case is another $100. Still, I know of nothing that's $500 new that offers 4+ inputs (LCR + LFE is the minimum required for a serious multichannel audio speaker manager, IMO), 8 outputs, Mac-compatible software, and both balanced/unbalanced I/O. Actually, I know of nothing else with that feature set period...
Aaron Smith
I've been very tempted by the MiniDsp products, but keep hearing many industry and HT install guys say they just don't have the quality circuits/parts to handle anything above the subwoofer range without jacking up the sound.
The people with vendettas against miniDSP are mostly just your standard audio industry con-men, such the greasy charlatan hack you mention above.
it's worth noting that Dr. Geddes, Dr. Kreskovsky, and others find the miniDSP adequate for their flagship music/HT loudspeaker designs (GedLee Abbey, the NaO and NaO Note lines, etc). After playing with mine a bit I've no qualms whatsoever about running my three front mains through it. (I have to, to blend the "flanking subs" with the mains.")
IMO, the only concern with running the miniDSP into mains is that it has a nasty turn-off thump. I think using the remote in/out will make it work just fine in normal use, but if one lives in an area that's prone to power outages (or people who like to pull cords out of the wall, etc.) then one could be going through drive-units at an undesired pace. That's why I bought a UPS for mine!
Edited by DS-21 - 12/20/12 at 5:21pm
