Originally Posted by
bass addict
What would be the advantage, if any, of using a DSP if one is currently utilizing an SMS1. Deciding if I need to pick this up for my current build.
Ability to provide separate EQ, level control, and delay for each subwoofer.
Diesel 48
Looking at getting a mini-dsp for my subs. I am currently running a Marantz AV8801 as a Pre with an outlaw audio amp. I have two subs currently running in my room. Which mini DSP do I need for this setup? I eventually will be running 4 identical subs but they will be sharing channels. I will be powering the subs with a LG clone. Which plugin should I purchase for it to? Thanks for the suggestions!
I would start by not having the subs share channels. The degrees of freedom one gets by being able to vary individual level, delay, and to a lesser extent EQ make system optimization much much much easier.
