AVS › AVS Forum › HDTV › HDTV Technical › OTA to HDMI projector
post #1 of 3
I've been using an old comcast box as a tuner to receive the signal and send it on to a DVI projector. However, I just upgraded to a new projector w/HDMI. Currently I use an HDMI to DVI adapter. However, I'd like to buy a BD and at the same time do away with the comcast box. Does anyone know of a good BD with a tuner? I have a surround sound now so it doesn't really matter to me whether the video out is HDMI or DVI. Suggestions? Other work-arounds?
Hope this forum isn't completely dead yet!
post #2 of 3
Other than a HTPC, I haven't seen a BD player OTA tuner combo.
post #3 of 3
Does not exist.
Get an A/V receiver with HDMI switching, connect the BD and Comcast STB to it via HDMI, and you are all set. Or if you want to 'do away' with the Comcast STB, still use the A/V receiver and BD, and get a HDTV tuner with HDMI, and you are all set. Except for needing an antenna for the HDTV tuner.
  Back to Forum: HDTV Technical
