I have been looking through several threads and have gotten an idea of what I may want, but I still have to go to Best Buy to listen to different speaker systems to compare.
However, the issue I have is the room that the system will go in. It is a 22ft long by 14ft room. The two main seating positions are pretty much at that 19ft distance from the tv, but a 3 seat sofa is located along the wall that is on the right channel side of the system. The back of the room (behind the main seating) is the kitchen. Due to lack of space, the rear surrounds will go mounted to the wall almost to the ceiling. Oh, and the floors are tile.
The receiver I have pretty much set in stone: pioneer vsx-1020-k
For the speakers, at least by what I have read, I will look into the following speakers.
Front L/R: Polk Monitor 60
C: Polk CS2
Rear L/R: Polk Monitor 30 maybe
Sub: BIC F12 or Bic PL-200 (will go near front left corner)
The two things I'm worried about is the size of the rear speakers and the subwoofer. Since the rears are going to be wall mounted, I want smaller speakers. Are there any others that you would recommend? About the sub, I will keep looking in the sub forum here. I have seen plenty of discussions about those two listed there.
C: Polk CS2
