Originally Posted by
Chad T
Thanks for the reply. All I have is an older RS analog SPL meter.
With the subs gain matched and hooked into the single sub input with a y-cable, Audyssey set the sub distance at 10.5ft.
Last night I re-adjusted the subs to level matching and hooked one sub into the sub1 input and the other into the sub2 input, then I re-ran Audyssey. It calculated each sub's distance as..........10.5ft. I am running my subs in the front of the room in this order left to right: left main, sub, center, sub, right main. So in my setup the ability to set different delay settings is nil.
I need to spend more time with it, but it did sound like the one sub was strained a little bit with the new (level matched) configuration.
Since your subs are equidistant to the primary LP, there is no benefit to running them on 2 separate outputs, especially since Audyssey found their distances the same. If there is some disparity in the gain settings with level-matching, and one of the subs sounds distressed before the other, then gain-matching makes more sense. However, if you go back to gain-matching, you'll want to re-run Audyssey.
Chad T
Something occurred to me. All I need to do is gain match the subs, then measure them separately and make note of the levels. Then switching between level and gain matching can be done in the comfort of the seating position with the Onkyo's trim levels using the remote control. However, I wonder if changing the sub levels in relation to each other will wreak havoc on Audyssey's EQ filtering, Dynamic EQ, etc.
Changing the trims is different than gain-matching. Changing the trims changes the input signal. This will change the level, but it won't change the gain structure of the amp. If you want to gain match, the only way to accomplish this is by setting the gains on the amps to the same gain setting, as described earlier in the thread.
Changing the relative trim levels will impact the Audyssey EQ filtering and DEQ. If you want to change the trims, they should both be changed by the same amount. However, then your subs will no longer be properly calibrated to the speakers.
If you change ALL the trims of all the speakers and subs by the same amount, you will still be "calibrated", but you'll screw up "Reference Level" and that will screw up DEQ.
Bottom line, I don't recommend adjusting the trims after running Audyssey, especially if the only measurement capability you have is an SPL meter.
Craig
