AVS › AVS Forum › A/V Control & Automation › Home Automation › Lutron Home Works Software Question
post #1 of 7
Hello,
I am using the latest Lutron software to program a HW processor 8 system. I am trying to download the current program in the current running system. It looks like when the last installer uploaded the file, it was a minimum upload, so when trying to download I get a message that says, since last upload was minimum, the down load file running on the system will not be the file running on the processor. Is there away to compile what is in the processor so I get the full running file?
Thanks JR
post #2 of 7
No. The "download" from the processor is the retrieval of a copy of the control program that was compressed and saved in a separate location in the processor during the last full upload. That's all that can downloaded, so whatever changes that were made since the last full upload will not be in the retrieved program.
post #3 of 7
Thank you for the reply.
post #4 of 7
Hi, I have a Lutron HomeWork8 series and like to obtain the programing software. Anybody knows where I can download it for free? Thanks
post #5 of 7
Hello,
You can download it from here,
http://resi.lutron.com/
JR
post #6 of 7
Thanks a lot, I will try here!
Best Regards!
post #7 of 7
How did you make out? Did you find the software?
  Back to Forum: Home Automation
