AVS › AVS Forum › Video Components › Home Theater Computers › HTPC Will Not Hibernate or Standby??
post #1 of 15
For the past few weeks I have not been able to get my HTPC to hibernate, so it has been running all the time. This weekend I had time to try to get this to work with no luck. I cannot get it to go into Standby mode either. The cause of the problem may be a new sound card I installed. Short of removing this card and trying it what are my other options? It is a pain in the butt to get the PC moved where I can work on it. The card is a Diamond Extreme Sound - model #XS71DDL.
Any ideas?
post #2 of 15
Remove the card and see if it really is the cause.
post #3 of 15
Instead of actually removing the card I went the uninstall route. Hibernation worked after that. I bought this card due to MB audio messing up and I really like it.
So are there any ideas for me to have this card and get hibernation to work?
post #4 of 15
Look for updated drivers, or older drivers. Install only the drivers, and not any software the comes with it.
post #5 of 15
Run "powercfg -devicequery wake_armed" to see if the soundcard is configured to wake the system.
You can also run "powercfg -requests" to see what devices are requesting the computer to stay awake.
You can also run "powercfg -lastwake" to see if the computer goes to sleep but something is waking it up.
post #6 of 15
I tried an old version and the latest version of the drivers and hibernation would still not work.
Any other ideas??
post #7 of 15
Being hibernation worked without the sound card then shouldn't it be configured correct? Without the card it hibernates and I can wake it.
post #8 of 15
It would let you know what is keeping the computer awake. It might be a program installed by the soundcard, it might be the soundcard itself, etc.
post #9 of 15
I am trying to "powercfg -requests" but it is not working. Another screen pops up for a second than nothing else happens.
post #10 of 15
You need to open the command prompt first. Run cmd.exe, and then type in the powercfg command. You might need to run cmd.exe as an Administrator.
post #11 of 15
Now it says this is not a recognized internal or external command.
If it makes any difference I am using XP.
post #12 of 15
Ah yes it does. Those options were added with Vista/Win7. You'll only be able to run the -devicequery one.
As an aside, I'd recommend upgrading to Win7. The Family Pack is back this season. It has 3 upgrade licenses for $150.
post #13 of 15
I really do not want to switch to Windows 7. Thanks anyway.
Any other ideas out there?
post #14 of 15
Have you contacted Diamond Multimedia about it?
post #15 of 15
Yep - below is their response.
"As far as we know Our sound cards do not and can not stop a computer from going into hibernation or stand by. The control over that option is in windows itself. normaly found in the display properties"
