AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Is my receiver good enough?
post #1 of 8
I have a vintage Marantz 2230B and I want to buy a set of B&W DM685's (or similar speakers) to use as my bedroom system. Is the old Marantz good enough for these speakers? It sounds fine with the set of hand-me-down Bose 301's I'm using now, but those sound pretty muffled (3-inch paper cone tweeters? Really? In this era?). I'm worried the more detailed B&W's will only serve to bring out its flaws. Any input is greatly appreciated. Thanks!
post #2 of 8
IMO, evidence suggests amps don't sound much different. If it's working ok, I say use it until it stops working (unless you are worried about it catching fire)
post #3 of 8
I knew of one specialty A/V retailer that used "vintage" Marantz AVRs to drive some of the Dynaudio speaker models which, I believe, are more difficult to drive than the B&W's you mentioned. So, as Michael indicated, you probably won't have problems driving the B&Ws.
post #4 of 8
Thanks. I was just wondering since it is nearly 40 years old. Obviously they've made some improvements since then and I was just wondering if it would be noticeable. I prefer this to a new receiver. I bought it because I love the look, with the aluminum faceplate and blue lights. Plus it's unique, nobody else my age has anything like it, just a bunch of miserable iPod docks. As a bonus it also sounds better than a much more modern Sony I have to compare it to.
post #5 of 8
Not sure how much amp designs have changed in 40 years. Of course, an amp that old could have some issues. Some capacitors have limited lifespans, for example.
post #6 of 8
Your new B&W's will sound awesome with any amp. Not to say that a better amp won't improve them, but that whole listening experience is so subjective. Regardless you will love those speakers over your bose 301s.
post #7 of 8
I've heard about capacitors going bad. What are the signs of them going bad?
If they were to die I would probably just have this amp repaired, as long as it isn't outrageously expensive. Even if I had to replace it I would get another vintage Marantz. There is some distortion but I'm 90% confident it's the speakers, because I have to use a ton of equalization to make them listenable and it's forcing way more treble and bass out of them than they were built for.
post #8 of 8
The signs depend on where it's located in the circuitry when it starts to fail. Anything from a buzz in one speaker to dead silence on one - or both speakers. Chances are they either need replaced now or soon will - especially if you give it a workout often.
